T56 in a Dak?
Old Dec 16, 2009 | 03:20 PM
95_318SLT's Avatar
95_318SLT
Now I can understand low transmission gears and high pumpkin gears causing that! For every gear reduction, the torque is multiplied in the drivetrain, so just for simple math if an engine is putting ou 500 ft*lbs of torque, and your 1st gear in the transmission is 4:1, the u-joints have to deal with 2000 ft*lbs of torque, and then if your rear pumkin is say 3:1, now your differential and axles have to deal with 6000 ft*lbs of torque. If you flip that around and your transmission has the 3:1 reduction and your pumpkin has the 4:1, your u joints are now only dealing with 1500 ft*lbs but the axles are still dealing with 6000. Make sense?
Old Dec 16, 2009 | 10:24 PM
grswat's Avatar
grswat
That .50 6th gear is exactly what I'm looking for. It seems to me that your final drive ratio would determine how much stress you are putting on your drivetrain components. So if I have a .69 overdrive right now with a 3.55 rear my final drive is 2.45...I think. So with a .50 overdrive with my current rear will give me a 1.78...i think again....so to get back to my 2.45 I would need a 4.9 rear which I don't think even exists for the 8.25 rear end. Anyways I'm not concerned too much with tearing stuff up until next winter when I pull the 318 and make it a 390.
Old Dec 17, 2009 | 08:39 AM
grswat's Avatar
grswat
My last post didn't really have a point now that I reread it. Anyways has anyone ever bought a car on copart.com . There are 3 v8/manual Z28 Camaros on there within 250 miles of me. May be worth it to buy a whole car to get transmission and then part out whatever is left. I wouldn't mind having an ls1 around.
Old Dec 19, 2009 | 12:05 AM
Hahns5.2's Avatar
Hahns5.2
Keisler sells a T56 kit for 97-04 Dakotas FWIW..
Old Dec 19, 2009 | 01:48 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Cool your right. Here is the link. A little high though.
http://www.keislerauto.com/mopar-faq.html
Old Dec 20, 2009 | 12:12 AM
dodgerules86's Avatar
dodgerules86
Guys, I've been at work too long.
I saw T56 and I thought... "that's the engine my planes have on them!" 4,200 to 4,591 prop shaft HP.
http://www.af.mil/shared/media/photo...-0194K-537.jpg
Old Dec 20, 2009 | 12:44 AM
95_318SLT's Avatar
95_318SLT
LOL!! That'd be fun! That much hp, who would need a transmission, just use a 1:1 straight-ran drivetrain!
Old Dec 20, 2009 | 12:56 AM
mazda7475's Avatar
mazda7475
it does slt! but im just looking in my head as low torque engine, low torque tranny, and high gears, somethings gotta give. im thinking u-joints.
your the math guy but i understand exactly what your saying.
Old Dec 22, 2009 | 03:35 PM
murdered93'kota's Avatar
murdered93'kota
2 grswat. if your plannin on running the t56 and keeping your stock 8.25 i w ould suggest going up to the 9.25 from a newer truck. ive blown up 2 8.25 and a ford9" under my truck. y idk but i did. the first 8.25 was a 3.90, the 2nd was a 3.55 and the 9" was a 2.73. im now running a 9.25 from an 02 durango that has 3.92 gears in it and its a very easy swap and a very strong axle
Old Dec 23, 2009 | 06:42 PM
mazda7475's Avatar
mazda7475
changed my mind. after reading what dodgerules wrote i think it's good. i would rather replace u-joints on a monthly bases than a tranny.
am i being sarcastic. who knows
