1992 Error Code 41
Old Dec 14, 2009 | 08:53 PM
stymie222's Avatar
stymie222
Default 1992 Error Code 41
I have a problem with readings on my battery gauge. All my lights are dimming and getting over bright while the gauge shows a decrease and increase in voltage.
1992 Dakota 3.9L LE
I just had a new alternator installed but still have the problem.
Error code 41- Generator feild not switching properly.
I suspect the ECM and voltage regulator that is built in.
Any suggestions are welcomed, especially a reliable company to buy a new or rebuilt unit. It looks like I can probably install this myself ??
Also had failure of EGR sytem which should be unrelated and will post elsewhere.
Thanks
Old Dec 14, 2009 | 11:11 PM
Crazy4x4RT's Avatar
Crazy4x4RT
If it is not the alt. It is a wire problem. Or a computer problem. But most likely it is a wire problem. Check the alt first. Take it to most auto parts stores they can test it for free.
Old Dec 15, 2009 | 12:49 AM
stymie222's Avatar
stymie222
Default Info
New Alternator professionally installed and checked for proper voltage- but will retest.
Could the ASD relay cause this problem ?
Severe fluctuation of volt meter (pegs all the way down and up).
Lights dim severely and then over bright.
Thanks
Old Dec 15, 2009 | 12:54 AM
Crazy4x4RT's Avatar
Crazy4x4RT
No the ASD relay will not cause it.
Old Dec 17, 2009 | 01:59 PM
stymie222's Avatar
stymie222
Default Update
Installed used ECM/ECU Module
Everything works !
Thanks- Great Forum !
Old Dec 17, 2009 | 04:21 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Glad you got it working!
