swap trans
Old Jan 13, 2010 | 04:15 PM
rhino907's Avatar
rhino907
Default swap trans
looking to change trans. wondering if 92 2wd v6 auto trans. fit in 89 atuo 4x4 v6? if not what would?
Old Jan 13, 2010 | 04:18 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It will bolt up to the engine but not the transfer-case. You would have to swap out tail shafts and tail housing from an another 42rh.
It is better to rebuild yours or find another one for a 4wd.
Old Jan 15, 2010 | 02:16 AM
rhino907's Avatar
rhino907
so any first gen auto trans for a 4x4 v6 will work? oh and thanks not really a auto trans guy like my 98 4x4 5sp ex cab 318. ypkamf
Old Jan 15, 2010 | 02:24 AM
Crazy4x4RT's Avatar
Crazy4x4RT
92-95 V6 4x4 from a Ram, Van, Dakota will work. You can also use a V8 transmission too. Same year.
Old Jan 16, 2010 | 07:16 PM
mazda7475's Avatar
mazda7475
pull the tail piece of the 2x4, insert the transfer case, put the tail piece of the 4x4 on the end. you will have to change from a rod linkage to a cable linkage or the other way. either replace the throttlebody gear to work with a cable or change the tranny setup to work with a rod. either way it's simple and your set because you got parts for both and there interchangeable. i would go with the cable setup off the 92.
