Tilt lever
How do you remove the tilt steering lever on the side of the steering column on a 93 Dakota LE 4WD stretch cab? Lever shaft looks like it is milled flat up next to the head...put a small wrench on it and go counter-clockwise to remove? Anyone done this? I don't use tilt much, but need to get to the multi-function switch...any help is appreciated.
