Problems with OD (noob learning)
This is to show my truck as I drive it, Please tell me if I sucked at OD.
Notice that at 40 secs it starts vibrating.
[youtube]Nk94qwd3cXE[/youtube]
let me know what can you find.
If your ECT sensor (code 22) is bad, then your computer won't shift the transmission into overdrive at all!! The computer has to have a particular reading from that sensor before it lets the transmission make that shift.
To be honest, it never looked to me like your transmission shifted into OD in that video. You never got it fast enough. At 35-40 mph, 3rd gear and TC locked would put it at the rpms it was at in that video. You need to get it up to 60-70 before anything is noticably wrong.
As for the shaking, that entire video was shaky!
My 4.0 explorer was geared very tall, by NOT using 5th, I GAINED nearly 2MPG, consistently... My truck is on the verge of being too tall geared with 31s, I ran a couple tanks not using 5th under 60, gas mileage was unchanged...
It very well could, you of all people should know that lower RPMs doesn't always equal more MPG...
I understand what your saying and I agree. I never put my truck into 5th until I'm over 50 mph. But I'm still waiting for the day you learn that just because its true with your truck it automatically makes it true for everybody elses! The fact is the OP has a factory 2wd... stock size tires, stock gears. Driving on flat ground around 45 (speed mentioned in the first post), he won't get better gas milage in 3rd than 4th! Driving up a steep hill, sure, knock it down into 3rd, but driving on back country roads, overdrive will help.
Hmm, you got me on the 3.9L comment. That engine probably does get better gas milage with higher rpms cause its having to work it's a$$ off in the low rpm range! I didn't even think about that before.
Lol, I don't believe your comment: "...many people have reported getting better MPG on other forums by not using OD at all..." If you're going 70, you need OD no matter what engine or gears or tires you have!
