Will I need to change out my axle if I swap the motor?
Old Jan 23, 2010 | 12:38 AM
Scaryjam8234's Avatar
Scaryjam8234
Default Will I need to change out my axle if I swap the motor?
I have a 96 Dakota with a 3.9 V6 auto transmission. I'm planning on swapping out the the v6 for a v8 later down the road this year. I'm getting a 318 or a 360. Anyways my question is will my rear end be able to withstand the torque and additional horsepower with the bigger motor on the stock rear end or will I need to replace the rear end to handle the motor? I'm a complete noob when it comes to rear ends so forgive me if its a dumb question.
Old Jan 23, 2010 | 12:45 AM
95_318SLT's Avatar
95_318SLT
It depends on what rear axle you have. If its the 7.25", you should get that upgraded to an 8.25 or 9.25. If it is an 8.25, you're fine, but if you really want to could upgrade it to a 9.25. The 9.25 is only available on the 2nd gens.
Old Jan 23, 2010 | 12:47 AM
Scaryjam8234
Well I'd prefer to not upgrade if I don't have to. I will if I have to but I'd rather not. Ill check tomorrow morning to see which I have. Thanks.
Old Jan 23, 2010 | 12:55 AM
95_318SLT's Avatar
95_318SLT
And to add one thing, you will need to upgrade your transmission.
Old Jan 23, 2010 | 01:42 AM
Scaryjam8234
Yea I'm aware of that. The transmisson will becoming from the donor vehicle as will the motor and ever essential thing I need. Thanks anyways though. I always love to see people that wanna help
Old Jan 24, 2010 | 12:18 PM
Scaryjam8234
Ok my axle is 7.25 so ill need to replace it. Will the axle from the donor vehicle work in my truck if its a van, jeep, ram, or durango? Or am I'm going to need to purchase an axle from somewhere that will work in my dakota?
Old Jan 24, 2010 | 01:54 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes the donor axle can work. But depending on where it comes from you may need to change the drive-shaft or brake fittings or something. Durango and Dakota axles should all be an easy swap in.
