Interchangeable parts
Old Jan 31, 2010 | 09:29 PM
Crash0311's Avatar
Crash0311
Default Interchangeable parts
I just purchased a 94 Dakota, 4x4, 5.2L Magnum V8, extended cab and it is need of some love. My question is what model year(s) parts are interchangeable with my truck. My knowledge is pretty limited so any help will be appreciated.
Old Jan 31, 2010 | 09:33 PM
Az93DKota's Avatar
Az93DKota
Most same year Jeeps as far as drive train.
Old Jan 31, 2010 | 10:02 PM
myfirstruckdak93's Avatar
myfirstruckdak93
It just depends which part you need, but a site that helped me get information was http://www.car-part.com/. It searches parts of other years and perhaps other makes that would fit onto a 1st generation dodge dakota. Keep in mind though it's a salvage yard database, so not all parts are going to be in good condition.
Old Jan 31, 2010 | 10:56 PM
95_318SLT's Avatar
95_318SLT
Actually there is almost nothing the same about the drivetrains between our trucks and jeeps. The jeep has the starter on the other side so although they have the same transmission, they can't be used because the bellhousing is different. The transfer cases are also the same model numbers, but jeeps have different slip yokes and driveshafts, so they aren't directly swappable either.
Basically, some stuff is swappable with Rams and 2nd gen daks, but you are mostly limited to our trucks.
Old Jan 31, 2010 | 10:59 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it depends on what part. But the engine and transmission will be the same as rams, vans, durango, Dakotas, jeep grand Cherokee.
Old Jan 31, 2010 | 11:17 PM
Crash0311's Avatar
Crash0311
Thanks, right now I want to start with the interior but there is alot I want to do.
Old Feb 1, 2010 | 12:03 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Interior will be only Dakotas 1987-96.
Old Feb 1, 2010 | 12:07 AM
95_318SLT's Avatar
95_318SLT
Lol, actually, even some of the interior peices had slight changes throughout the 1st gens!! If you have power windows, the switches moved (I forget what year) from the middle of the door panel to the top. The instrument clusters changed. Most stuff should be swappable though.
Old Mar 1, 2010 | 07:43 AM
JD852000's Avatar
JD852000
I was hoping to put a 125MPH cluster in my 87 Dakota but I don't know where I can find or if I can use the speed sensor gear out of the correct transmission. let me know if anyone can help. thanks!!!
Old Mar 19, 2015 | 02:19 PM
Millrat2's Avatar
Millrat2
Default 1994 Dodge Dakota
I have the 5.2L magnum V8 4x4 also. Getting into the guts of the dash. Previous owner worked real hard on it and there are many broken parts. Is there a resource for parts inside this truck?
I am also looking for head lights to replace the factory ones. They are plastic and faded. Cleaned them several times but I would like to go to the glass lens if possible and improve the lumens. Looking for a running light retrofit package too.
Anything out there?
