Help Diagnose Stuttering
Old Feb 7, 2010 | 05:01 AM
duburban's Avatar
duburban
Default Help Diagnose Stuttering
My 94 v6 is stuttering on acceleration. Sometimes feels like it going to stall out. I had a distributor go out on an integra once and it feels similar, cruising along and suddenly engine is stumbling. Before i replace the fuel pump, what can i do to check things off the list. I know there is a common problem with the rotor connections on these trucks. Should i do a fuel pressure test? All ideas would be great. Parts are a little more expensive on big island hawaii than mainland so i want to avoid changing out parts if i don't have to. I've done plenty of part swaps on different cars but my diagnosis skills are lacking. Thanks!
Old Feb 7, 2010 | 07:49 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes start by testing the fuel pressure. Then check your timing, and check all your spark plug wires are correct.
Old Feb 7, 2010 | 04:44 PM
95_318SLT's Avatar
95_318SLT
If its not the ignition or fuel causing the problem, I'd say check the TPS and MAP sensors. You can run basic tests on them if you have a multimeter. You can find the procedure for testing them in the FSM (look for the link to download in faq2).
Old Feb 7, 2010 | 07:02 PM
duburban's Avatar
duburban
I do have a multimeter to test them and i will later today. Since i don't have a fuel pressure tester I'm looking on ebay. How do i know which setup to buy? I guess i'll need to look at where it connects in my truck. But if you've seen a cheap one that will work on ebay let me know. This is simple stuff i know, but its new to me. I also have the same question about which ball joint tool i should get for the dodge. Can i get one tool that will do the truck and say honda cars?
Old Feb 7, 2010 | 10:39 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Get the kind that screws into the fuel rail. Its like a tires valve stem. Just much larger.
