3.9 motor swap
Old Feb 7, 2010 | 11:25 PM
89dakota318's Avatar
89dakota318
Default 3.9 motor swap
I have an 89 dakota with a 3.9 4x4 5 speed. I was wondering what v8 motor will match up to my bellhousing
Old Feb 7, 2010 | 11:32 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Any mopar small block will. But you will blow that V6 transmission fairly quickly. That transmission is only made for a V6. If you need info on a V8 swap check the FAQ2 in this section for several posts on it.
95_318SLT's Avatar
95_318SLT
Any small block mopar engine. You probably will want to look for an LA 318 or 360 since they are very easy to come by.
Old Feb 7, 2010 | 11:35 PM
89dakota318
what year motor should I look for?
Old Feb 7, 2010 | 11:36 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Depends on what you want to run. Carb setup? Throttle body Injection? Multiport injection?
Old Feb 7, 2010 | 11:38 PM
89dakota318
carb. I am only getting 9 mpg as it is so a carb will be fine
Old Feb 7, 2010 | 11:42 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I'm not sure when they started the LA blocks but anywhere from 60-89 will work. Around 90 or so the LA's were Fuel injected. Look for Rams, Vans, Probably even some larger boats cars from the 70's might.
Old Feb 7, 2010 | 11:46 PM
89dakota318
will the stock motor mounts work? and thanks for all the help
Old Feb 7, 2010 | 11:51 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It depends on the motor you get. Here is a link with info you need. Again this is from the FAQ2 with tons more info on the V8 swap. https://dodgeforum.com/forum/1st-gen...ml#post1413374
