95 dakota Transfer Case issue
Old Feb 9, 2010 | 07:28 PM
Dodge4lyfe's Avatar
Dodge4lyfe
Originally Posted by 95_318SLT
If you're hearing crunching noises and its not staying in position, it sounds to me like its time to take it out of the truck and open it up!
But just to rule out the linkage adjustment as a possibility, loosen the linkage, put the transfer case in 4Hi, put the shift lever in the 4Hi position, and tighten the linkage. Should only take about 5 minutes to adjust. You'll need a 9/16 wrench to turn the transfer case shifter.
That was the plan for tomorrow...I gotta remove the skidplate to be able to better access the linkage and check the level, and it's too dark to see well now...
Old Feb 10, 2010 | 11:27 PM
Dodge4lyfe's Avatar
Dodge4lyfe
well, I tore it out and it's in the shop...Hopefully they can tell me if its useable or if i should junk it...
Old Mar 23, 2010 | 12:07 PM
'95 Dakota's Avatar
'95 Dakota
Default '95 3.9liter v6 dakota
Old Mar 23, 2010 | 05:22 PM
Dodge4lyfe's Avatar
Dodge4lyfe
ah it was junk..got a different one...being run dry it looked like someone had taken a handful or rocks and dumped them in there and then drove it around for a month. Hell after one week the fluid that I did put in there looked like liquid anti-seize, all gray and full of silver shavings...
