IAC or VACUUM Leak?
Old Feb 15, 2010 | 03:19 PM
Senate427's Avatar
Senate427
Default IAC or VACUUM Leak?
vehicle- 93 dakota reg 4x4 auto v6 180k
My truck in the past couple of months has been making a hissing/breathing sound or like my engine is exhaling around where the IAC sits. Also on every other start up my truck will shake and sometimes almost stalls. Today I notice the IAC fault code showed up on my OBD computer and so I replaced it. The new IAC didn't make a difference. I noticed that where the PCV hose line connects to the combustion chamber it's been making a buzzing sound through the hose.
So far I replace my throttle body gasket, EGR valve, PCV, IAC, and some vacuum lines in the past 10 months.
What could be the problem?
Thanks
Old Feb 15, 2010 | 03:31 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The IAC are very problematic. Even new are faulty quite often. So you could have gotten a bad IAC or you have a wire problem. Since you have a code the computer is telling you there is a problem in that circuit.
The IAC can make the hissing sound. It is normal. The PCV do make a rattling sound due to it working.
Old Feb 15, 2010 | 07:41 PM
Senate427's Avatar
Senate427
I was able to erase the IAC code and I believe the only reason that code appeared is because I got the IAC wet from throttle body cleaner yesterday. I know the PCV rattles but what I meant is the hose is vibrating like a hand massager and makes a weird buzzing sound that's pretty loud. My engine is rumbling and shaking on every other start but once I start to accelerate it runs smooth and doesn't do anything until the next start up.
