Leaf Spring Bushings
I thought about doing all the above except the blocks of coarse. For me it would be for articulation. Keep it the same hight. But I got TONS of articulation so it is not needed. Just would be cool!
Also why not just build your own shackles. Just 2 spacers and 2 brackets. Very simple to make.
Trust me Felipe, I will avoid using blocks as much as possible! You know I feel the same way about them as you do! And I am definately planning on paying a visit to the junkyard for some 2500 or 3500 springs (I forgot to mention that before). I will need all the help I can get for preventing axle wrap!
BUT... if the hanger swap, longer shackles (I won't go over 2 inches), and repacked springs don't get her high enough, I'll use cheater blocks to get the rest. Its not like the other mods won't get me a heck of a lot more articulation! But I just can't afford to pay for high-arched springs right now. Heck, the only reason I haven't started this swap already is cause I'm over budget and have to wait on buying the last couple parts (which should be coming up within the next week).
What I would really love to do is set up a ladder bar suspension with dual-shackled leaf springs! It would be simple enough and just a little bit different.
I just found the easiest, fairly cheap solution to lifting the rear.
I'm going to order all new stock bushings for the leaf springs, and get these shackles...
http://www.ruffstuffspecialties.com/...ge-6-p-67.html
...and attach them to the factory shackles after the flip (have 2 shackles on each side). That will give me tons of downflex!! Also, being 6 inches long, plus whatever the hanger swap gives, plus repacking the leaf springs should let me avoid using blocks.
