4 Cylinder to 318
Old Mar 4, 2010 | 01:06 AM
Slimjim707's Avatar
Slimjim707
Default 4 Cylinder to 318
So I have a '93 RCSB 5 speed Dakota with a 4 cylinder in it and I just picked up a complete '01 RCSB with the 5.2 in it. Everything's good, except the 46re, which is on it's 5th rebuild, and is totally shot. I also picked up a good NV3500 complete with clutch. I tried searching, but couldn;t find anything specific to what I'm looking for. I was wondering if anyone has done a swap like this and could give me some advice. My main concern is the motor mounts; I know I'm going to have to do some fabrication, and was looking to see if anyone had a write up or possibly pics. Any info anyone out there could post would be a big help. Thanks.
Old Mar 4, 2010 | 02:21 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Nothing specifically for the 4cly swap. But a few have done it. The little info we could get off of them said they it is an easy swap. I'm guessing it all bolts in place. For V6 to V8 check out the FAQ2. If you do the swap do a write up for us.
Old Mar 4, 2010 | 02:08 PM
95_318SLT's Avatar
95_318SLT
If you need to know what to do to get the transmission behind the engine, I have a write up linked in faq2 about it.
As for getting the engine into the truck, I think I remember hearing the mounts are the same, but I'm not positive.
But assuming you get the engine and transmission in the truck without any problems, what are you going to do for wiring? Are you going to try to wire in the OBDII computer and harnesses? That would suck to say the least. But all 4 cyl are throttle body injected, and your engine is port injected, so you are going to need an OBDI engine harness and computer.
Old Mar 4, 2010 | 05:17 PM
Slimjim707's Avatar
Slimjim707
Well I'm going to use the computer and wiring from the Ram, and just hopefully unplug the connector for the transmission from the PCM. I know the engine runs fine without the trans hooked up at all, and I'm not worried about a CEL. Thats good news about the few who have done it saying it's an easy swap. I measured the engine in the Ram and the engine bay in the 'Kota and it looks like it's gonna be a little tight, but I think electric fans will solve a little of the clearance issue. The motor mounts in the Ram appear to be a lot farther forward in the engine bay than those in the 'Kota, but I guess I won't know for sure until the motors come out and the fun begins.
