You know you own a Dakota when?
Old Mar 7, 2010 | 01:07 AM
  #41
shadowthedakota's Avatar
shadowthedakota
you go to work and all your coworkers come running out saying, "thank god your truck is okay. we thought something bad happened." after a spin out the night before
Old Mar 7, 2010 | 01:37 AM
  #42
JDakota92's Avatar
JDakota92
You know you own a Dakota when you open the hood and realize, "There's a V-8 in there!" (or at least enough room for one)
Old Mar 7, 2010 | 02:09 AM
  #43
mazda7475's Avatar
mazda7475
yah jdakota92. you put it best. open the hood on an 89 sport 4x4 3.9 and theres lots of room left. bet i spent 3 seconds to figure things are not right here.
thanks for the laugh guy1
Old Mar 7, 2010 | 02:19 AM
  #44
JDakota92's Avatar
JDakota92
You know you own a Dakota when you do front brakes and the previous owner has already stripped out the caliper pin holes on the knuckle.
Old Mar 7, 2010 | 02:59 AM
  #45
mazda7475's Avatar
mazda7475
only the front passenger side at the top. finally gave up on the repair and replaced the knuckle. there is a few companys that have healy-coil repair kits but they did not work for me because i had a lot of miles on it from when i bought it.
Old Mar 7, 2010 | 12:26 PM
  #46
JDakota92's Avatar
JDakota92
I faced that same problem when I replaced my ball joints. The truck was down for an extra two days while I hunted down a replacement knuckle for the driver's side.
Old Mar 7, 2010 | 02:12 PM
  #47
Az93DKota's Avatar
Az93DKota
When you look at the axle tag and it says 3.73, then crack open the diff and find it stamped 3.55 %%%##^*#
Old Mar 7, 2010 | 02:13 PM
  #48
Az93DKota's Avatar
Az93DKota
BTW, you guys are doing great at pointing out the Dakota's short comings. Keep it coming cause I'm enjoying the laughs.
Old Mar 7, 2010 | 02:30 PM
  #49
LO 619's Avatar
LO 619
after you replace the door locks the electric locks no longer work
Old Mar 7, 2010 | 02:32 PM
  #50
LO 619's Avatar
LO 619
when you go to change the oil in your front differential and realize you can't remove the front skid plate cuz the front bolts are ruined.
