Help with Blinkers
Old Mar 8, 2010 | 08:53 PM
wheeler1977's Avatar
wheeler1977
Default Help with Blinkers
Hi,
I have been having problems with my 93's blinkers. They work intermittently, but don't work more then they do.
Anybody have this problem?? Is it something I can fix myself???
Thanks!
Old Mar 8, 2010 | 09:28 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Probably a wire problem. Sorry but we can't diagnose it for you over the Internet. We have wiring diagrams in the FAQ in this section.
Old Mar 8, 2010 | 10:11 PM
Az93DKota's Avatar
Az93DKota
Play with the switch and see if thats bad. Maybe check the flasher relay under the dash. See if its clicking funny.
Old Mar 8, 2010 | 10:33 PM
shadowthedakota's Avatar
shadowthedakota
i had that problem before, it turned out to be a bad ground at the rear lights...but like crazy said check the wiring diagram and test the switch
Old Mar 11, 2010 | 09:01 AM
jbarth24's Avatar
jbarth24
I've been dealing with the same problem for a while now too. I just replaced the flasher/relay and it fixed it. Good place to start because it was only about $9 to replace.
Old Mar 12, 2010 | 01:02 PM
wheeler1977
Thanks for the replies, I have already replaced the relay and it didn't do anything.
I will try a new switch.
It's annoying 'cause if I unplug the relay and plug it back in, they'll work again for a bit.
