Bog and high idle
Old Mar 8, 2010 | 11:53 PM
JGC403's Avatar
JGC403
Default Bog and high idle
The truck is a 1989 Dakota, 3.9L, 5-speed, 4x4. I have a couple of drivability problems I am not sure if they are all connected.
When I start it up in the morning it will rev up a bit and the rpm will drop bellow idle and rev up again then settle out at its normal idle speed.
When I push the clutch in sometimes, to cost to a light or stop sign, the rpm will rev up a a couple 100 rpm and won't go back down to idle, 750 rpm, until the truck comes to a complete stop.
When I floor it, sometimes it will bog down for a second, then it will take off. I am not sure if that's just something you have to live with with TBI or if something is wrong.
Thanks,
Old Mar 9, 2010 | 12:47 AM
Crazy4x4RT's Avatar
Crazy4x4RT
My guess is a vacuum leak.
Old Mar 26, 2010 | 02:01 PM
JGC403's Avatar
JGC403
So I replaced all the vacuum lines inside the engine compartment. Also replaced the Idle Air control motor, the old one's gears were stripped.
I think I still got a leak though. I crawled under neath near the transfercase, there is a sucking sound. Is this sound normal with the transfercase, if not this is probably the source of my vacuum leak.
I also got a hold of a scanner, and I found out that she is idling rich. Could be a result of the vacuum leak or some other problem. Haven't drove it with the scanner yet, to see if its always rich or not.
Old Mar 26, 2010 | 05:13 PM
Crazy4x4RT's Avatar
Crazy4x4RT
The transfercase has a vacuum operated switch to control the CAD Central Axle Disconnect. The switch is on top of the transfercase. It probably is broken or disconnected.
Old Mar 26, 2010 | 05:25 PM
JGC403's Avatar
JGC403
So if its broke it would be inside the transfer case? Easiest way to test this, I guess would be to jack up all 4 wheels, put it into 4 wheel drive and see if the front wheels turn.
