91' dak running bad
Old Mar 10, 2010 | 08:36 PM
usaweapon777's Avatar
usaweapon777
Default 91' dak running bad
Hey guys, I've been working on my dakota on and off and it seems that it's running really rich. I mean after it sitting idling for a while you can smell the truck from like 15ft away. Also the sensor that controls the throttle always tries to keep the idle high for like 3-7 sec after giving it throttle. Any help appreciated. It is a pretty beat up truck but i've been working on it. Also it doesn't have a muffler if that helps. Old one looked peeled open like a banana so i took the sawzall to it.
Old Mar 10, 2010 | 09:34 PM
Az93DKota's Avatar
Az93DKota
Whats the plugs look like? They can tell a lot about what an engine is doing and not doing. You probably need to clean the IAC and intake. Your exhaust will smell bad if you take the CAT off.
Old Mar 11, 2010 | 07:35 AM
dk sport's Avatar
dk sport
also checkthe hose that goes to the map on the front of the tb
Old Mar 11, 2010 | 08:17 AM
tmacdakota's Avatar
tmacdakota
And run your codes.
Old Mar 11, 2010 | 09:44 PM
usaweapon777
alright thanks for the advice will check those things out tom when i get the chance. Also it still has the CAT on
Old Mar 15, 2010 | 05:27 PM
usaweapon777
Alright well besides realizing i need new spark plug wires.( I barely touched one and it fell apart) Heres some pics of a plug. I was gonna take apart the iac but the rain started up again.
Old Mar 15, 2010 | 05:55 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Looks like they have been running hot. Not bad looking, could be worse. Just replace them.
Old Mar 15, 2010 | 05:59 PM
usaweapon777
They are new plugs. AZ93DKota said to take em off and look at them. I figured they look good though. I'll take the iac off and clean it when the weather clears up hopefully tom.
Old Mar 17, 2010 | 07:18 PM
usaweapon777
ALRIGHT, well i finally got the iac off and cleaned it out. The truck seems to run better with the idle coming down faster but still not as fast as it should. I think i'm going to replace the iac how much are they?
Old Mar 17, 2010 | 07:21 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Go to www.autozone.com and see how much it is.
