Fuel Gauge/pump question
Old Mar 11, 2010 | 11:04 PM
Dodge4lyfe's Avatar
Dodge4lyfe
Default Fuel Gauge/pump question
I know the fuel gauges on these trucks are notorious for going bad because the sending unit tabs corrode. My question is, is the sending unit built into the fuel pump on the 95's? I have several websites saying they are integrated and a few saying theyre separate...I assume it's an integrated sending unit if it's anything like my 95 Intrepid...My fuel gauge is not at all accurate and spends most of its time wandering between the pegs, so it's time to get it taken care of...any help would be appreciated.
Old Mar 11, 2010 | 11:36 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes the fuel pump is integrated on to the sending unit. You have to buy it all as one unit. They usually run $200 or so.
Old Mar 11, 2010 | 11:38 PM
Dodge4lyfe's Avatar
Dodge4lyfe
yeah i know...i found one for $118...
Old Mar 11, 2010 | 11:55 PM
shadowthedakota's Avatar
shadowthedakota
Originally Posted by Dodge4lyfe
My fuel gauge is not at all accurate and spends most of its time wandering between the pegs...
does yours stop at the lines when it gets to that point in the tank?
Old Mar 11, 2010 | 11:58 PM
Dodge4lyfe's Avatar
Dodge4lyfe
When tank is full-about 1/2 the gauge wanders at standstill and sits on E while moving. As it gets to 1/2 down to 1/4 it seems to work normally, but once it hits 1/4 tank it just stays there and doesn't move. It's really wierd...
Old Mar 12, 2010 | 06:16 PM
ksc_31's Avatar
ksc_31
My '95 did something similar - bounced around randomly between full and about 1/3 full, then was steady till about 1/4 full when it would just say I was on empty. Replaced the fuel pump with integrated sending unit with one from Pep Boys and haven't had any problems since.
