rough running ' 93 dakota 5.2 litre
Old Mar 16, 2010 | 05:56 PM
tommykat's Avatar
tommykat
Default rough running ' 93 dakota 5.2 litre
Help! My Dakota will start running and idling very rough for no apparent reason. It acts like someone threw a switch, it will be running fine one minute, then acting likes it's missing. Does not not seem to matter much about temperature of engine, wet or dry out, etc. any suggestions. thankx
Old Mar 16, 2010 | 11:51 PM
Crazy4x4RT's Avatar
Crazy4x4RT
A bad Idle could be a bad IAC Idle Air Control valve. You could try replacing it. You could also have a vacuum leak. Many other possibilities. A tune up like plugs wires dist cap and rotor change all oils and all filters.
