I really need some advice.. Please help
Old Apr 7, 2010 | 01:38 AM
LO 619's Avatar
LO 619
Default I really need some advice.. Please help
So, I've been driving the Dak alot recently and I keep getting this weird issue, sometimes everything is fine and then other times it just plain scares me.... it's not good. I don't feel it's safe.
So far this has happened regardless of gear 1st, 2nd & 3rd it doesn't seem to matter. Although it seems worse in the lower gears. I'll drive off in 1st and I get this crazy hesitation/bogging down like I'm putting on the breaks and then accelerating and I mean it SLAMS the truck back and fourth sometimes, I don't know a better way to describe it then that. The slamming seems very dangerous, I have to put my foot down hard on the gas to get it to recover it's really strange!!!
Also It's recently been idling high, before It'd get a little shaking probably because of the exhaust, but now it seems like the rpms are up on the idle. I don't know if these 2 things are related because it was doing that before the other thing first.
My trans also has a leak, I need to fill it again I'm sure. I just need to know what the deal is so I can fix it or know where to start.
btw v6 5spd manual
Old Apr 7, 2010 | 02:06 AM
Crazy4x4RT's Avatar
Crazy4x4RT
A vacuum leak can cause idle and hesitation issues.
Old Apr 7, 2010 | 06:01 AM
grswat's Avatar
grswat
Any check engine light?
Old Apr 7, 2010 | 01:12 PM
LO 619's Avatar
LO 619
Nope no check engine light. I'm going to look for a leak today. And I might check my EGR and just replace the gasket while I'm at it. Dos anyone know a good way to clean up the EGR valve if it's got alot of carbon buildup?
Old Apr 7, 2010 | 03:29 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Carb cleaner.
Old Apr 7, 2010 | 04:53 PM
LO 619's Avatar
LO 619
Ok, so I went ahead and checked the EGR... HOLY S^&T it was plugged up bad. There are 2 holes one for air and one for exhaust? The round one was completely blocked on the egr. I spent a good 15 mins cleaning it up. I used carb cleaner a flathead screwdriver & a wire brush to get it all out and put in a new gasket. I started it up and what a difference! I took it around the block and I think it's the best my truck has ever run. I'm hoping I fixed the issue. 3 dollar fix!
Old Apr 9, 2010 | 06:59 PM
Jsny1010's Avatar
Jsny1010
PCV Valve.. and the breather into the other side...
Mine was clogged w/ bees (breather) and my PCV was bad..
I also swapped my fuel pump but almost all of that is taken care of now.
I had the same issue, now its good (it was usually when i was slowing down tho almost like it was rocking the truck back and forth)
Old Jul 5, 2010 | 08:10 AM
LO 619's Avatar
LO 619
Yes, I still get the issue and it has to be fuel delivery, So a new fuel pump and strainer is next on the list. but may be a bit before I can buy the parts.
****ing truck needs EVERYTHING.
Old Jul 6, 2010 | 12:24 AM
shadowthedakota's Avatar
shadowthedakota
have you replaced the fuel filter yet? its one of those preventative maintenance things that should get done. i replaced mine when it was fine and it turned out to run even better.
Old Jul 6, 2010 | 12:10 PM
LO 619's Avatar
LO 619
Yea I replaced it a couple months ago
