1995 dakota sport wat to do
Old Apr 12, 2010 | 06:27 PM
1995 tt dakota's Avatar
1995 tt dakota
Question 1995 dakota sport wat to do
so today i dropped the rear of my dakota 5inchs and the front is higher than the back im thinking about cutting the springs wat do yall think thanks for the help
Old Apr 12, 2010 | 06:31 PM
1995 tt dakota
Here the pic of drop
Old Apr 12, 2010 | 06:34 PM
1995 tt dakota
Heres the pic of dropName:  myslab.jpg
Old Apr 13, 2010 | 12:04 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Sure you could cut the springs. But that usually will drop to much. Use a torch to heat up the spring. That is the easiest way to drop it.
Old Apr 13, 2010 | 10:29 AM
LO 619's Avatar
LO 619
That sounds like it would be inconsistent, how could you get both sides the same?
Old Apr 13, 2010 | 10:31 AM
LO 619's Avatar
LO 619
btw, customdakotas.com has everything you need to know about lowering, air ride etc.
Old Apr 13, 2010 | 11:02 AM
JDakota92's Avatar
JDakota92
I guess it's too late to tell you not to cut the springs. You should be able to get some lowering springs for the front and rear.
Old Apr 13, 2010 | 12:20 PM
bill55az's Avatar
bill55az
Cutting is iffy, you have to know what you are doing....how much does a set of lowering springs cost? Sometimes the extra money is worth it as you get to avoid a lot of aggravation.
Old Apr 13, 2010 | 01:49 PM
Crazy4x4RT's Avatar
Crazy4x4RT
There are several lowing kits in the FAQ2 in this section.
Old Apr 13, 2010 | 03:32 PM
95_318SLT's Avatar
95_318SLT
I would NOT get lowering springs. I would get drop spindles. They will drop the front 2 inches without changing your spring rate, ride quality, or factory suspension geometry.
