fuel pump
Old Apr 12, 2010 | 09:16 PM
dakota26's Avatar
dakota26
Default fuel pump
hello i have a qustion about the diff brand name fuel moudle one is a walbro the outher one is a carter here is the problem one has 6 connection for the fuel pump moudle and the outher one has 4 or 5 connection can i get a pigtaile 4 the 6 coonection to the 4 or 5 one and will the 4or 5 one work with my truck its a 96 dakota 3.9 the walbro has a Fuel Pump Gallons Per Hour 52 gph the carter has a Fuel Pump Gallons Per Hour 34 gph. the walbro has a Fuel Pump Pressure Rating 48 psi the carter has a Fuel Pump Pressure Rating 64 psi
Old Apr 13, 2010 | 12:19 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Carter is more well known. I would suggest Napa products. It all will work as long as it is for your truck by part number.
Old Apr 14, 2010 | 03:41 PM
dakota26's Avatar
dakota26
hey thanks crazy4x4rt truck runing again
