help reinstall front drive axle
Old Apr 17, 2010 | 03:52 AM
duburban's Avatar
duburban
Default help reinstall front drive axle
hey, got upper and lower joints replaced with some cheap ebay parts... should last a few months. how do i seat the axle shaft into the knuckle/hub assembly? it does not slide right in. i haven't wire brushed the splines but what do you guys usually do?
Old Apr 17, 2010 | 10:39 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes it should slide in. If not try rotating it. Check both sides for nicks and burs that will make it stick.
Old Apr 17, 2010 | 04:16 PM
95_318SLT's Avatar
95_318SLT
If it goes in just far enough to get the nut on the end, run the nut in to pull the axle shaft in place.
Old Apr 17, 2010 | 06:10 PM
duburban's Avatar
duburban
just got it. needed a good cleaning from where the axle splines welded themselves to the bearing. finished it off with the nut.
Old Apr 19, 2010 | 04:41 AM
duburban's Avatar
duburban
i'm looking back at this project thinking about how many tools i broke. without lifetime warranties this would have been expensive.
the hub nut is on so damn tight. i broke a breaker bar 1/2" taking it off and a torque wrench 1/2" putting it back on. exactly what tools are you using to make this possible.
i wasn't able to torque the hub nut after i broke the torque wrench, i just went f'n tight with a craftsman 1/2" ratchet and a 3 foot cheater pipe. you guys use torque wrenchs that go up to 200ft pounds?
I also warped the c clamp part of my ball joint press! wtf!? lower ball joint had a lip that was rounded over the top of the control arm instead of the snap ring! should have ground it off...
i'm wondering if hub nuts should be done with 3/4" drive tools....
these questions might seem silly but its the little things that add up and obviously im new. all advice appreciated.
Old Apr 19, 2010 | 10:15 AM
shadowthedakota's Avatar
shadowthedakota
it might. i know i broke a 3/4" breaker bar trying to remove a hub nut off my friends 93 dakota.. soaked it with pb blaster then tried it and the tip snapped right off, and that was a huge a$$ breaker bar too.
Old Apr 19, 2010 | 03:30 PM
95_318SLT's Avatar
95_318SLT
I use a 1/2 inch pnuematic impact wrench to spin the nut off... takes about 2 seconds to get it off.
I use a BFH on all joints that need to come off.
I have a Snap-On torque wrench that goes up to 250 ft lbs.
Honestly, the best invesment you can make is a 60+ gallon, 3+ horsepower air compressor and some decent air tools. They will always make a job go way faster.
Old Apr 19, 2010 | 05:10 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Not always! Once for me, my air or electric impact wouldn't. I broke 3 breaker bars before that. I took it to 2 tire shops they couldn't with there way more HD impacts and they couldn't get it. Finally I had to go to a 18 Wheeler (Semi Truck) tire shop. They had there Jack Hammer size impact that finally did it.
Old Apr 19, 2010 | 05:25 PM
95_318SLT's Avatar
95_318SLT
Dang!! Who put that nut on there?!?! My impact has never failed to take any nut or bolt off my truck. I've got all 3/8s air fittings on my air lines though... no 1/4 inch, so my air tools get no lack of air!
And those cv axle nuts are put on at something like 190 ft*lbs.
Old Apr 20, 2010 | 12:39 AM
duburban's Avatar
duburban
i'm too nomadic for a compressor right now but my dad has a 18 cfm compressor waiting for me in vermont.
next time i go at this ill be using a 3/4 breaker bar, impact adapter to 1/2 and the 1/2 hub socket.
think its worth taking the ball joint press C clamp to a machine shop to press it back? the C started to open when one of the joints was in there so tight... might be out about an 1/8 inch or so. will it stay is the question...
how many ft lbs should i get minimum for a impact wrench?
off to kauai tomorrow! be back beginning of may. talk to yall soon.
