Any options for a fuel kill switch?
Old Apr 26, 2010 | 02:02 AM
oxygen454's Avatar
oxygen454
Exclamation Any options for a fuel kill switch?
My friends car got stolen right beside my truck a few nights ago and Im wondering how hard it would be to make a kill switch to cut the power to the fuel pump?
I would think tapping into the fuel wiring which supplies power to the pump would not be too hard? Maybe under the fuel/replay box under the hood in the engine bay?
Old Apr 26, 2010 | 10:16 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It wouldn't be hard at all. A simple switch routed to the fuel pump relay. You can mount the switch anywhere dash, under the seat, on the side.
Old Apr 26, 2010 | 10:20 AM
shadowthedakota's Avatar
shadowthedakota
make sure you put a relay in there to for it, and hide it. I did that to my truck and hide the switch in a very (secret) hard to find place. anybody who tries to steal my truck would have to tear the interior out to find it.
Old Apr 26, 2010 | 06:17 PM
oxygen454's Avatar
oxygen454
Hey shadowthedakota. Why do I need a replay? Would a switch not be deficient enough?
Bwdakrt from dodge-durango was saying "Don't know if your '93 is the same as the Gen III trucks, but look for a grey connector plug beside the PDC under the hood with a single brown wire leading down to the starter. Splice the switch into the brown wire and that will kill the power to the starter."
Is this wiring setup on our year of truck too? Might be a another way of doing a disable.
Old Apr 26, 2010 | 10:14 PM
shadowthedakota
it depends on where you put the switch. if you do what i did and wire it between the fp relay and the fuel pump depending how far away it is the added relay help keep resistance in the wiring(in other words you won't burn out the switch to fast). I learned that lesson the hard way and almost set my truck on fire. if you place it in that (brown? i believe ours is pink) wire to the starter then it should be fine to just put a switch in.
but make sure you put the correct amp switch in...
Old Apr 27, 2010 | 05:54 AM
oxygen454's Avatar
oxygen454
I think your right about the pink wire. I need to verify that it is correct though lol. I think I might do that, put a switch in there where the starter wire is. And a high amp switch that is not illuminated.
I was hoping to connect to a 12 guage wire system so I dont have to run large anything larger through my truck. So if its the wiring that carries all the power to the starter, that my not be my best option.
Old Apr 27, 2010 | 10:18 AM
shadowthedakota
its the wire that comes off the asd, i believe.
Old Apr 27, 2010 | 10:30 AM
shadowthedakota
you could also put the switch on the p/n wire. my grandpa did that on his truck and just mounted it in an obvious place though(base of the floor shifter)
Old Apr 28, 2010 | 06:56 AM
oxygen454's Avatar
oxygen454
What is a asd and a p/n wire?
Old Apr 29, 2010 | 12:09 AM
shadowthedakota
asd - auto shutdown and p/n wire - park and neutral wire(p/n comes off the transmission. if it isn't grounded the starter wont crank)
