need advice!!
Some times when I push my clutch in when stopping my engine stays reved up for a little bit. Also sometimes when I crank it up after driving it for a while the idle is really low for a min, and it eventually will pick up on its on or when I hit the gas. Any help would be appreciated.
My ideas in order of likeliness are:
1) Bad IAC
2) Bad TPS
3) Bad MAP
I remember my idle did some really weird things when I first did my manual transmission swap, and it took me 2 or 3 IACs before one finally worked the way it should!
1) Bad IAC
2) Bad TPS
3) Bad MAP
Get some carb cleaner and clean clean clean before you change out any sensors. A friend of mine had the same problem on her 4cyl FORD. And turned out the IAC was dirty as homeless underwear. With that being said, I had to change out the IAC anyways cause it was a magnetic problem. And if anyone here has attempted to change one on a FORD is probably why they own a DODGE.
