oil pump and seal
Old May 2, 2010 | 01:27 AM
Big_Phil's Avatar
Big_Phil
Default oil pump and seal
hey im gettin ready to rep[lace my oil pump and rear main seal. i was wondering about the RMS. do i have to lossein all of the main bearing caps or wat? and wat do they need to be torqued to afterward. thanks
Old May 2, 2010 | 03:16 AM
Crazy4x4RT's Avatar
Crazy4x4RT
For the pre magnums I'm not sure what is required. But I suggest you try the online manuals we have listed in the FAQ in this section.
Old May 2, 2010 | 12:35 PM
kahanabob's Avatar
kahanabob
is a 2 part seal the top half slips around the top of the crank. think you may have to pull it around with a tool? my mech did mine did not have to loosen any main's.
Old May 2, 2010 | 12:52 PM
Joezilla64's Avatar
Joezilla64
I did mine a couple weeks ago. You would only have to loosen all the caps if you can't get the top half of the seal around the crank shaft. I didn't have to loosen any.
