speaker size for 95 extended cab
Old May 3, 2010 | 11:12 AM
1995dakotaslt's Avatar
1995dakotaslt
Default speaker size for 95 extended cab
what size speakers are in the rear in a 95 dakota slt extended cab. the ones in there now are blown and sound like hell.
Old May 3, 2010 | 01:41 PM
will4557's Avatar
will4557
They are probably 5x7s. I am not a hundred percent sure but that was a common size.
Old May 3, 2010 | 01:58 PM
ice_cold1959's Avatar
ice_cold1959
The only info I could find shows a 5 1/4" in the front and a 5" x 7" in the rear.
http://www.modifiedlife.com/1992-dod...iring-diagram/
Old May 3, 2010 | 03:33 PM
95_318SLT's Avatar
95_318SLT
Yes, they are 5x7s in the rear, 5 1/4s in the front. Keep in mind that there are typically no differences between 5x7s and 6x8s!
Old May 3, 2010 | 09:27 PM
will4557's Avatar
will4557
Just something to add I have 6 1/2s in the front doors on mine. I put them in there last week. 2 screws will line up and go in with no modification. they sound much better than the 5 1/4s I took out. also the vent looking plate fit back on and everything looks good.
Old May 3, 2010 | 10:39 PM
shadowthedakota's Avatar
shadowthedakota
i did a tiny bit of fabrication with a plasma torch...ok a lot of it but here i got to use a torch...anyway i threw 6x9's i nthe doors and 6x9s in the rears, and now i'm going to setup some 4.5in speakers as subs with 2 300w amps.. this should be good..
Old May 3, 2010 | 11:20 PM
95_318SLT's Avatar
95_318SLT
4.5" speakers as subs?!?! They won't be able to move enough air! The 6x9s will produce better bass than those little speakers!
Old May 3, 2010 | 11:26 PM
shadowthedakota
thats what the previous owner did, surprisingly but i'm not looking for a whole lot of bass yet. i'm in a crazy testing phase and i'm looking to wreck my old 4.5 speakers anyway, since a got a brand new set in a trade. after i get those destroyed i have 2 12in subs to throw in with a custom box.
Old May 6, 2010 | 08:30 AM
1995dakotaslt
thanks for the help
Old Jan 6, 2017 | 07:28 PM
Kimberly Robbins's Avatar
Kimberly Robbins
They are 5x7. An the front is 5 1/4
