Turn Key, all power, No Start?
Old May 8, 2010 | 02:13 AM
oxygen454's Avatar
oxygen454
Points go to Az93DKota! I tried to start the truck today and nothing. I wiggled the shifter and bingo, she started. The weird thing is, it was fine after I wiggled the shifter. Now it doesn't do it anymore? So if this become a issue, how do I go about fixing it?
Old May 8, 2010 | 02:24 AM
95_318SLT's Avatar
95_318SLT
Replace the park/neutral safety switch.
Old May 8, 2010 | 02:30 AM
oxygen454's Avatar
oxygen454
lol that simple? No cables or other wiring? Sweet! Big thanks for everyone's help!
Old May 8, 2010 | 02:35 AM
95_318SLT's Avatar
95_318SLT
That simple. The P/N SS is the only thing between the shifter and the starter!
Old May 8, 2010 | 02:39 AM
oxygen454's Avatar
oxygen454
Great, thanks for the help! I might see if I can get a few more days out of it, as long as I don't get stranded. Thanks!
Old May 8, 2010 | 02:50 AM
95_318SLT's Avatar
95_318SLT
No reason to rush into replacing something that aint broke yet! It won't leave you stranded... when the day comes that you can't start the truck in park, throw the shifter in neutral to start it, get where you need to go, and then replace it.
Old May 8, 2010 | 03:13 AM
oxygen454's Avatar
oxygen454
Cool, not only did you help me but you also saved me money haha. I will take your advice and run it till it brakes.
Old May 8, 2010 | 01:39 PM
Az93DKota's Avatar
Az93DKota
I still have the ol' shifter starting problem. Always had it. I guess we may need to adjust something. Anyone know what top adjust?
Old May 9, 2010 | 01:48 AM
oxygen454's Avatar
oxygen454
Reading what 95_378SLT wrote, it sounds like there is no adjustment. Basically replace the bad switch when it goes. Or in your case, if its a constant problem and has not quit yet and is an ongoing annoyance, to replace the switch.
Im not sure how much work is involved but shouldn't be to hard to replace.
Old May 9, 2010 | 01:57 AM
95_318SLT's Avatar
95_318SLT
Its very easy to replace... getting to it sucks though. Just unplug the harness, unthread the switch, thread the new one in, plug the harness back in. Shouldn't take more than 5 minutes with a 2 minute coffee break half way through :P
As for adjusting, you can try making a very minute adjustment on the shift linkage, but you don't want to throw the shifter or indicator off by too much.
How that switch works is that there is a contact for Park, Reverse and Neutral. The Park and Neutral contacts ground their circuit when the shifter is in Park or Neutral, so the computer knows it, and the Reverse contact completes the reverse light circuit to turn those lamps on. Adjusting the linkage by a very small amount could provide a semi-fresh contact surface, but its hard to say if it would be worth the effort or not.
