Still looking for new carpet
I thought I was close, and I was, but the manufacturer claims the only carpets they make are for the 2WD extended cab Dakota, and that from 1992-1996 years it won't work with a 4WD Dakota. Anyone know the difference? I can't figure it out, unless the floors were different by the transfer case shifter.
I think the only difference is the hole cut out in the floor for the shifter! I can't think of any other difference there would be. Just cut your own hole... its not hard! I had to cut my carpet for the 5 speed swap.
The 4wd had a hole for the shifter. Just buy the 2wd one and mark it and cut it.
http://www.stockinteriors.com/ (I believe they have all the options)
www.jcw.com
www.jcw.com
http://www.wlsheadliners.com/dodge-d...996-p-240.html
I've heard bad stuff about carpets from StockInteriors.com, such as poor fit, etc. WLS makes their own. I haven't actually bought anything from either source though.
www.jcw.com
www.jcw.com
I got shipped a carpet which was for a 2WD, and even though they said it would fit it didn't, they had it listed incorrectly on their website. The transmission hump is a different size, so you will need to get the correct carpet for your truck.
So where did you end up getting a replacement carpet? Mine was trashed so it's definitely gone. I am wondering if the 4WD standard cab flooring will fit back to the the rear of the seat and I can just cover what is left with something else? Anyone have any input on this?
Trending Topics
I don't know if this will help, but check out this link....
http://www.jcwhitney.com/custom-tail...id=d412y1991j1
