Need help with bracket locations and vacuum lines
Hey guys, just got a new long block dropped off for the 90 LE, 3.9 mag
I was currious if any of you could take some pictures of your bays (3.9's) so I can have an idea of the locations of the components/wires/vacuum lines. Right now the block is assembled out of the truck, heads are on, timing chain/cover/water pump/ and Harmonic Balancer are on, even though I know ill need to take 1/2 of the bolts out to put the accessory brackets back on, just need to know which one is bolted where. If you could lent any help it would be appreciated. Thanks.
Hopefully someone can. But if not you need you can go to www.autozone.com they have vacuum diagrams. Also check the FAQ for online service manuals that will have pictures of brackets, engine components ect.
Yeah i actually checked out the FAQ before i made an account, the service manual links are dead, so im going to try to get them on ebsco tommarow at school, if not ill stop by the automotive engineering and maintenance department and see if they can source a manual for me. I checked vatozone earlier, and got the crappy vacuum diagram from them, and got the electrical one as well. I also have a haynes, but its about as usefull as a set of **** on a boar hog. Anyways, thanks alot, and ill keep you guys updated on it as i make progress of getting this motor back into the truck.
