can antilock be bypassed??
Old Mar 24, 2009 | 08:14 PM
my91dakota207's Avatar
my91dakota207
Default can antilock be bypassed??
my 91 dakota has the brake and antilock light on,the fluid is fine,no leaks any where.is there a way to by-pass the antilock so the lights will go off,I dont lick antilock brakes to begin with.
Old Mar 24, 2009 | 08:16 PM
batman13's Avatar
batman13
you'll like them if you need them and dont have them...
you probly have a bad sensor
Old Mar 24, 2009 | 08:19 PM
my91dakota207
yeah I'd rather fix it then trash it,,is there a way to test the sensor so I know its one of the 2 and not the wiring?
Old Mar 24, 2009 | 08:59 PM
95_318SLT's Avatar
95_318SLT
Check the adjustment in the rear drums. When I did a bunch of standing burnounts to wear down my old tires when I got new ones, I ran the adjusters all the way in on the back brakes so I wouldn't have to fight them, and that turned both those lights on, so that would be something to check. To check them, just feel how much resistance there is when you pull off the drums, and if there is none, tighten the brakes until the you can just barely feel then rub.
I don't know a way to test the sensor, you might could just replace it, it can't be too expensive.
Old Mar 25, 2009 | 11:44 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I know on the 92-up you can just ground out the ABS dignotstic connector and that Will flash out the coes. It may work for older years.
Old May 19, 2010 | 01:13 AM
kikazzdakota's Avatar
kikazzdakota
ok same problem both lights on but rear brake lights not working heard from that a friend that it could be the switch on the pedal that is bad plus where the hell is that
Old May 19, 2010 | 01:41 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Here these may help. If needed more info check out the FAQ for the service manual. It has everything.
I believe both lights can be lit up by a bad fuse/ bad power or ground to the ABS module.
And the brake lights could be a bad fuse or bad power or ground wires or bad bulbs.
Old May 19, 2010 | 02:15 AM
kikazzdakota
ill look in to it crazy thanks dude again cops hate my truck as it is dont need to give them nother reason to pull me over =) lol
