Dakota manual tranny and transfer case
Old May 24, 2010 | 06:48 AM
psebowhnter's Avatar
psebowhnter
Well that sucks cause everybody that has one wants an arm and a leg for them and i found one that the place only wanted $175 dollars for but it is in a 94. So I figured it wouldn't work. And the guy there even said that the 94 t-case was slip yoke.
Old May 24, 2010 | 09:06 AM
Crazy4x4RT's Avatar
Crazy4x4RT
The 94 will work for your 93. And the rear output is a slip yoke.
Old May 24, 2010 | 09:28 AM
95_318SLT's Avatar
95_318SLT
Yes, the '94 will work on your '93, you just need to swap over your vacuum switch for the front CAD. The '94+ Dakotas don't have the front CAD system, so theres no vacuum switch.
And that sucks you can't find them!! I can get them all day long from the local u-pull-it junkyard for $115 out the door! It just sucks to have to pull one of those in the yard. Have you looked for a u-pull-it junkyard near you, like LKQ Self-Serve or similar?
Old May 24, 2010 | 05:29 PM
Auron's Avatar
Auron
totaly off topic what pse bow do you use
Old May 25, 2010 | 06:46 AM
psebowhnter
Well I found a yard near me that has four of them for $300. Which I am gonna go with, cause trust me if you guys do a search for one of those damn things through one of the internet searches i have seen them going for $600 to $900. I had 2 Dodge dealers tell me the same thing. As far as 93 only. Must be the vacuum thing. And I shoot a PSE Spyder V4.
Old May 26, 2010 | 01:25 AM
Auron's Avatar
Auron
sweet deal and im going old school with a carrol intruder carbon 2 from the mid 80's still shoots better then a lot of my friends bows too
