Shopping a 92 = A little hard to shift into 4X
Hey guys, I'm looking at a 92 to buy with 123,000 V8 the drive train seems great. The body wellll eh ah.
How hard should it be to shift into the various stages of 4 wheel drive?? It seemed a little hard to get into some of the gears ect. Thanks in advance
I have the same truck, it used to in like a hot knife through butter, even low range. Spiders gears went, and it was cheaper for me to bolt a used rear in, this one is also easy, just not as easy as the original. By the way my motor has 236,000 miles and perrsss. Unfortunatly I had to replace the trans at 217,000.
Yes, I'm still learning about the "shift on the fly" but I went slow and then stopped a couple of times. Then I could get it in but one time it did grind a bit without going in. I put it in and out a couple of times in 4h, 4l, N, ect.
The truck mechanically looks good ect for this issue that bugs me.
If I remember right the 92 had syncros inside to help with the shifting. But if they are torn up it will be hard to shift. That may be your problem.
Trending Topics
That's what I was afraid of. I haven't driven any of the 4wd yet and it just didn't seem right. I had to really fight it sometimes. Thanks guys, I think I'll pass and keep looking.
