brake problem
Old Jun 5, 2010 | 09:35 PM
purewill2003's Avatar
purewill2003
Default brake problem
Hello all, I have a 92 dodge dakota with a 3.9 v6. I am having problems with my brakes, the pedal is fine most of the time but sometimes especially on a hill or at low speeds the brake gets very hard to push. I have put a new master cylinder on it and a new brake booster. I have also checked all the brake pads and they are fine, at this point I am stumped so any ideas you guys can give me will be appreciated. thanks.
Old Jun 6, 2010 | 09:02 AM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the first generation Dakota section,
FF
Old Jun 6, 2010 | 12:19 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You may have a vacuum leak. Check your vacuum lines.
Old Jun 9, 2010 | 08:12 AM
purewill2003
Default reply
I have checked the vacuum lines and I can't find a leak does anyone have any other ideas. Once again my brakes work fine driving down the road but if you are at low speeds or stopping on a hill the pedal gets real hard to push. Any ideas would be appreciated
Old Jun 10, 2010 | 05:13 PM
veejr's Avatar
veejr
have you checked the brake pedal linkage? Might be a dry pivot point binding.
Old Jun 18, 2010 | 12:36 PM
purewill2003
Default another problem
Ok, so I have a new problem. The truck is running a little weird and sometimes when you stop it will die and then the check engine light will come on. If you shut it off and start it back the check engine light goes off. i have run the code and it keeps coming up 02 sensor but i have changed it twice and reset the computer both times. I have no idea what is going on. Thanks for any help.
Old Jun 18, 2010 | 04:09 PM
Crazy4x4RT's Avatar
Crazy4x4RT
If its telling you the 02 and it is not the sensor then it is the wires. Check the wires!
Old Jun 18, 2010 | 07:06 PM
BAMF1500's Avatar
BAMF1500
a vacuum leak sounds possible, i know you said you replaced the booster, but if you went cheap on it it may be leaking internally, its possible for a vacuum leak to throw an 02 sensor code, dtc's just point you in a direction o2 code dosent always mean its the sensor.
Old Jun 18, 2010 | 08:14 PM
purewill2003
Thanks to everyone for the ideas, i will try those things and see what happens. If anyone has anything else, please let me know.
