dakota 360
Old Jun 10, 2010 | 04:27 PM
dakotart360's Avatar
dakotart360
Post dakota 360
im swaping the 3.9 for a 5.9 i was wondering what kind of mount to use my 89 is 4x4?? any ideas
Old Jun 10, 2010 | 05:01 PM
Auron's Avatar
Auron
crazy will know he did the same thing
Old Jun 10, 2010 | 05:19 PM
Crazy4x4RT's Avatar
Crazy4x4RT
I actually did a 5.2 Magnum to a 5.9 Magnum. Totally different.
But for the 3.9LA to a 5.9 is different. It also depends on what kind of 5.9 you got. Like LA which is 91-down. And if it is carbed or is TBI. Which most of the wires, computer, distributer ect will need to be swapped over.
Or a Magnum 92-up. Magnums come stock with MPI which you will have to swap all wires, sensors, computer, fuel pump.
As far a mounting up the engine I believe your stock mounts will work for both engine styles.
Read up on the V6 to V8 swaps in the FAQ2 in this section.
Old Jun 11, 2010 | 06:18 PM
LO 619's Avatar
LO 619
i want to see some good info on swapping an v6 la for a v6 magnum for down the road. something i am interested in. wondering about swapping the tranny & maybe even the transfer case as well?
Old Jun 13, 2010 | 02:01 AM
Auron's Avatar
Auron
is the la carbed?
Old Jun 13, 2010 | 02:18 AM
Crazy4x4RT's Avatar
Crazy4x4RT
is the la carbed?
Not all LA's are carbed. Somewhere like 89 or 90-91 they switch over to throttle body fuel injection. For the V8's anyways. V6 probably was earlier.
Old Jun 13, 2010 | 03:08 PM
95_318SLT's Avatar
95_318SLT
Wasn't '87 the only year the dakota was carrbed?
Old Jun 13, 2010 | 11:41 PM
dakotart360
my 360 is out of a 1980 custom400 dually 2wd thats y im wonderin about mounts
Old Jun 14, 2010 | 12:43 AM
95_318SLT's Avatar
95_318SLT
They should be the same. I know the 3.9 magnum and 5.2/5.9 magnum mounts are the same, so I assume the LA 3.9 and LA 5.2/5.9 mounts are the same as well.
Old Jun 14, 2010 | 06:22 AM
dakota89360's Avatar
dakota89360
kool well see what happens then
