dakota 360
Old Jun 14, 2010 | 12:00 PM
bill55az's Avatar
bill55az
Originally Posted by 95_318SLT
Wasn't '87 the only year the dakota was carrbed?
For the v6 yes, but the 4 banger in 88 was also carbed...
Old Jun 14, 2010 | 01:06 PM
bill55az's Avatar
bill55az
Originally Posted by dakotart360
im swaping the 3.9 for a 5.9 i was wondering what kind of mount to use my 89 is 4x4?? any ideas
Schmacher makes mounts, for $400 a set....
I sneaked a peak under a shelby dakota and what they did was add an extra crossmember in front of the stock one, right behind where the sway bar mounts. It is an odd looking thing, a half circle that fits under the motor right under the crank dampener. Kinda crowds the rack and pinion a bit...
That looks to be fairly easy thing to make, certainly cheaper than Schmacker.
I will be making one soon, will try to draw it up as I go....
Old Jun 14, 2010 | 03:12 PM
LO 619's Avatar
LO 619
Well my truck is EFI with a throttle body, and I've seen the print ads and original marketing stuff for the 88 and the EFI came standard.
Old Jun 14, 2010 | 04:52 PM
95_318SLT's Avatar
95_318SLT
But yours is a v6 isn't it? He said it was the 4 banger in '88 thats carbbed. And actually, we had that in FAQ if I had gone to look at it earlier...
Engines
I-4
2.2L Carb. 96HP 1987-1988
2.5L TBFI 99HP 1989-1995
2.5L TBFI 120HP 1996 (1)
V-6
3.9L Carb. 125HP 1987
3.9L TBFI 125HP 1988-1991
3.9L MPFI 180HP 1992-1993
3.9L MPFI 175HP 1994-1996 (2)
Old Jun 14, 2010 | 07:42 PM
bill55az's Avatar
bill55az
I am going by the 88 service manual, they could have switched mid year on the 4 bangers...
Old Jun 14, 2010 | 07:59 PM
Crazy4x4RT's Avatar
Crazy4x4RT
You were right. 88 4cly was carbed. Just like the FAQ Quote said and When in doubt check with www.autozone.com
Your 1988 Dodge Dakota 2WD 4 Cylinders C 2.2L 2BL has been saved
