truck acting weird?
Old Jun 19, 2010 | 12:26 AM
Deerkiller9991's Avatar
Deerkiller9991
Default truck acting weird?
I removed the radiator today and cleaned it, put it back in, flushed the system, etc. Now when I drive it, it vibrates when I have my foot on the gas accelerating or just keeping constant speed but stops when I take my foot off. It didnt do this before, so I dont know if water got where it wasnt suppose to go or if I didnt check the tranny fluid, cant remember. Thanks
1991 Dodge Dakota 318 V8 2x4 automatic
Old Jun 19, 2010 | 01:22 AM
Deerkiller9991
thinking it might be tranny fluid?
Old Jun 19, 2010 | 01:34 AM
89dakota318's Avatar
89dakota318
make sure you didn't get any water on the computer connection... I had that problem myself. pull off main plug and check for water...
Old Jun 19, 2010 | 01:55 AM
Crazy4x4RT's Avatar
Crazy4x4RT
It may be a miss or a vacuum leak. Maybe you accidentally hit one of the spark plug wires off.
Old Jun 19, 2010 | 04:39 AM
MagnumMan3.9's Avatar
MagnumMan3.9
I've switched radiators in my truck a few years ago and had the same problem, turned out to be the plastic fan shroud was vibrating. If it was me I would check to make sure all connections are tight and check for missing fan shroud screws, etc. I had used some black zip ties in place of missing screws which ends up looking nice and is fairly durable.
Let us know how it goes, good luck
Old Jun 19, 2010 | 10:07 PM
Deerkiller9991
Im thinking the distributor might of gotten bumped and made messed up the ignition timing. but imma check the spark plugs too. I know some vibration comes from the fact that my right shock is completly dead weight and the left one, i removed and busted the bottom bolts and still have to drill one of them out. Damn hard bolts, and spring in the way
Old Jun 20, 2010 | 11:09 PM
MagnumMan3.9
So your 100% sure that it wasn't doing that before the radiator swap? I've been in situations before where I only noticed a problem after I had just got done fixing another.
I would keep checking things around the front of the engine near the radiator though, it could be a lot of things. A loose cap on something, loose screws or bolts, loose wires...the list goes on.
You weren't very specific though. Is this vibrating something that only happens when the throttle is on and it's just vibrating something in your engine compartment area or is it like the engine itself is almost hesitating and chugging and moving around abnormally and causing your truck to shake and vibrate where you can actually feel it?
Old Jun 21, 2010 | 01:14 AM
Deerkiller9991
i can feel the vib. through the floor and its noticeable. i think your right tho. was probably there before. but i do know the ignition timings off, so i have to fix that, so it might be a mix between that and the shocks. but its not everytime i drive but sometimes it will do that, but guess thats the fun of it, troubleshooting
Old Jul 11, 2010 | 01:14 AM
MagnumMan3.9
So how's the progress going on this issue?
Old Jul 11, 2010 | 12:41 PM
Deerkiller9991
alls good. I didnt swap radiators, i ended up cleaning it out with HC acid. Stupid design with the radiator, up and down columns suck, be better if it were horizontal. but the viberation, i dont know still, I think its my suspension, it all needs to be replaced. tierods, shocks, etc
