91 Dakota 3.9 Idle Issues
Old Jun 19, 2010 | 08:05 PM
DrCheeto's Avatar
DrCheeto
Default 91 Dakota 3.9 Idle Issues
Hey guys, New here ,been a reader for a while, just never registered.
Anyway, I have a 91 3.9 TBI.
I CANNOT for the life of me figure out this random idle misfire / shake.
I've replaced : Plugs, Wires, Cap, Rotor, Checked timing chain for slack, Done a compression test (140's across the board), swapped fuel injectors, checked for vacuum leaks...
It drives absolutely fine, but the idle is just unbearable. Sometimes you can definitely feel the misfire at idle, but MOST of the time, it shakes the whole truck at idle. I understand these aren't the smoothest of motors, but this is ridiculous. Sometimes it will idle perfectly smooth, and other times its a constant shake, unlike a misfire.
It's difficult to describe, but i'm running out of ideas here.
Old Jun 20, 2010 | 12:49 AM
Bkilla's Avatar
Bkilla
have you replaced the PCV valve? its on the right valve cover/drivers side. after that its on the the EGR and check that. i got money on the PCV though.
Old Jun 20, 2010 | 08:49 AM
tmacdakota's Avatar
tmacdakota
Could also be a cruddy, partially obstructed fuel filter...might explain why it sometimes smooths out at idle.
Old Jun 20, 2010 | 09:10 AM
MagnumMan3.9's Avatar
MagnumMan3.9
Some aftermarket PCV valves that you buy new have a annoying buzzing sound though, which I learned the hard way just last year, you might just be better off taking some throttle body/carb cleaner spray such as this: http://media.photobucket.com/image/t...s/DSC07718.jpg to clean out your existing Positive crankcase ventilation valve.
If doing that doesn't fix your problem, I suggest taking out the idle air control sensor from the top rear of your throttle body and also cleaning it out with that spray. The spray also works ok for the EGR valve after you scrape the carbon out of the valve, the spray should get rid of the rest of the carbon dust and buildup.
It could also be things such as your ignition timing is off a little bit or maybe you have a weak, broken or loose wire on a fuel injector, it could be a lot of things. Your best bet might be to just call up a good mechanic that has a diagnostic computer and throw him a couple bucks to plug it in and see if any error codes come up, if it doesn't point you to the exact problem, it should point you to a general area. And while your there he could also check your ignition timing with a timing light if he has one. You don't need to go to a mechanic to try and resolve your problem, but in the long run it might just be faster and possibly even cheaper to just go.
Old Jun 23, 2010 | 07:52 PM
Flying's Avatar
Flying
Check EGR Valve to see if it is open,it should not be!
Old Jun 24, 2010 | 01:26 PM
DrCheeto's Avatar
DrCheeto
I junked the truck yesterday. Problem solved.
The transmission started puking from the front seal, and that was the final straw.
Old Jul 11, 2010 | 01:25 AM
MagnumMan3.9
Aw you junked it? lol.
