flywheel
Old Jun 27, 2010 | 12:42 PM
dakota89360's Avatar
dakota89360
i got all i need but a trans is where im stuck on
Old Jun 27, 2010 | 01:30 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Originally Posted by 95_318SLT
The t56 6 speed (the viper transmission) would be the best one!!!! It will bolt up and fit. It would only be 2wd though, obviously.
The only option at that point would be a divorced transfer case.
Old Jun 27, 2010 | 01:39 PM
shadowthedakota's Avatar
shadowthedakota
i just looked up the t56 on cl to see if any around... there is a vette one with bad syncros for 1200 obo or a viper one for 3650
"Viper T-56 Transmission: w/bellhousing, face plating, $3,650
Steeda shifter, Fidanza flywheel, DFX clutch,
Slave cylinder, & Spicer Yoke" ~ seller
Old Jun 27, 2010 | 02:51 PM
95_318SLT's Avatar
95_318SLT
Lol, I never said it was cheap! But it would be awesome. The .50 6th gear ratio would let you run 4:10s or 4:56s with near-factory size tires and still run at good rpms on the interstate. And with those low gears, the truck would haul in 1st-4th.
But back on topic... the nv4500 came on Ram 5.9 manuals... both 5.9s (the gas and diesel). You could use either, but you need the 5.9 magnum bellhousing. The case is tall and would require a 2 inch body lift to fit in the transmission tunnel.
But for a budget, the nv3500 should work. Like I said, since the Dakota is lighter than the Ram, it may hold up behind a 5.9L better in a Dakota than in a Ram.
Old Jun 27, 2010 | 08:31 PM
dakota89360
thanx for the info it really helps i got about 4jyards to scope out around my place so i should b able 2 come up wit something
