Lower radiator hose spring?
Old Jun 23, 2010 | 01:21 AM
Deerkiller9991's Avatar
Deerkiller9991
Post Lower radiator hose spring?
I bought a new lower rad. hose today at O'rilley and it didnt come with a spring, just the hose. The guy said it shouldnt need one but I thought thats what kept it from collapsing? any suggestions?
Old Jun 23, 2010 | 05:09 AM
Applehugger's Avatar
Applehugger
Just re-use the ones on your truck now. You are talking about the spring-clamps, right?
Old Jun 23, 2010 | 08:20 AM
tmacdakota's Avatar
tmacdakota
Nope, he's talking about the spring inside the hose. If the new hose doesn't have a spring, it's gonna collapse flat. I think you need to replace that rad, bro. Can you find one relatively cheap at a boneyard? I've used www.car-parts.com for years to source used parts. good luck.
Old Jun 23, 2010 | 08:27 AM
festerw's Avatar
festerw
Not all of them have the springs, the upper and lower hoses I got from Napa don't have springs and work just fine.
Old Jun 23, 2010 | 11:21 AM
Deerkiller9991
yeah the junkyard has them but their around 40-50 bucks. and i dont want to chance that with no returns. ill probably buy a new one from O'rilley with a lifetime warrenty. but ill check out that site.
Old Jun 23, 2010 | 04:41 PM
Applehugger
Hmm, never heard of springs inside of hoses. I recently replaced all the hoses on my truck and none of them, new or old, had springs in them.
Old Jun 23, 2010 | 05:41 PM
ice_cold1959's Avatar
ice_cold1959
I have had springed hoses, I find they are normally found where there are a lot of bends
Old Jun 23, 2010 | 08:17 PM
Deerkiller9991
Called O'rilley and they said to take spring out of old hose and put in new one. did it and it worked. bu t i found my problem, wasnt the hose collapsing, damn radiators clogged to hell. hello $250+ that i dont have
Old Jun 24, 2010 | 09:27 PM
will4557's Avatar
will4557
I bought one from advanced auto a while back. It is the one with the plastic top but it wasnt nearly that high. Im thinking it was around 150 or 160 bucks. If money is the problem you may have to go with the plastic top and bottom one.
Old Jun 24, 2010 | 11:12 PM
Deerkiller9991
i fixed my radiator. used a hydrochloric acid mix. cleaned it almost perfect. drove 65+ mpg for 20 miles, and 10 of which with the a/c on didnt even go to half (no thermostat) thank god. im happy now
