1993 V6 radiator in a 1991 V8? Need to know asap!
Old Jun 24, 2010 | 04:31 PM
Deerkiller9991's Avatar
Deerkiller9991
Post 1993 V6 radiator in a 1991 V8? Need to know asap!
I need a radiator and I found on 2 hours away but he had it for a V6, its brand new, but I have a V8 and the auto store said that the V8 one is about 1/4 inch thicker. His came out of a 1993 or 1994 and I have a 1991
the dimesnions for mine are
18 1/4" x 25 5/8" x 1 1/4"
and for the one he has
im guessing its about
17 5/8" x 25 7/8" x 1 1/2"
according to the one on oreilly's website for the 1993 v6
but it says its compatable to
1992-1996 Dodge Dakota
V8 - 5.2L vin Y 318ci - MFI GAS OHV
V6 - 3.9L vin X 239ci - MFI GAS OHV
V8 - 5.2L vin T 318ci - MFI CNG OHV
Old Jun 24, 2010 | 05:13 PM
Crazy4x4RT's Avatar
Crazy4x4RT
1/4 more shouldn't be to bad. Just go take a look to check if you can fit 1/4 more in front and in back. And the more thickness will help improve cooling power.
Old Jun 24, 2010 | 05:20 PM
Deerkiller9991
I think i mistyped something. The radiator from the v6 would be smaller than the v8 wouldnt it? i have a v8 and want the v6 radiator in my truck to replace the v8 radiator
Old Jun 24, 2010 | 06:45 PM
festerw's Avatar
festerw
I checked on that earlier, the hose outlets on the 92+ radiators are different. New 92+ are around $150 plus you'd need new hoses.
91 Radiator
Core Material : Aluminum
Tank Material : Plastic
Row No : 1
Core Height : 18 1/8"
Core Width : 25 1/2"
Core Depth : 1 1/4"
Inlet Header : 2 7/16" x 26 1/8"
Outlet Header : 2 7/16" x 26 1/8"
Inlet : 1 1/4"
Outlet : 1 1/2"
Toc : 14 3/8" (Concentric)
92+
Row No : 1
Core Height : 17 5/8"
Core Width : 25 5/8"
Core Depth : 1 1/4"
Inlet Header : 2 1/2" x 26 1/4"
Outlet Header : 2 1/2" x 26 1/4"
Inlet : 1 1/2"
Outlet : 1 3/4"
Old Jun 24, 2010 | 10:59 PM
tmacdakota's Avatar
tmacdakota
Try ABC Auto Salvage in North Platte...they are showing a rad for a 91 Dak with 5.2L V8.
Old Jun 24, 2010 | 11:09 PM
Deerkiller9991
fixed mine. thanks guys. used some hydrochloric acid mix.
