no spark problem
okay, so my friend's truck will crank, however it will not start. There is no spark out of the ignition coil. I have checked all of the fuses/relays (i think, even the ones that didn't go with the ignition system). I have heard something of the splice under the fuse panel but i need some more information on it & some more ideas of what the issue could be.
Thanks guys
It's a 94 Dodge Dakota V6 (3.9 L i think)
Thanks guys
I have a 94 dakota, 318, same no spark, fuel or check engine, motor turns over but no start, it turns out all it was is a badly corroded conection in the wiring harness, disconnect the battery for safety, cut approx 6-8" of the harness tape/ covering, starting at the main engine fuse relay block that sits beside the battery, you will find 4 red wires soldered together, mine was covered in white chalky powder and broken apart, clean everything up, connect back together with a wire crimp or something, should start instantly, good luck!!
