Northern Utah, southern Idaho?
First gen Parts available..
Any first gen owners near Logan Utah? I have some good parts available.
As I modify my 89, there will be parts removed and not used again.
First, a nice set of tires on stock steel rims with trim rings. Tires are mohawk p215/75/15 and are about 2 years old and barely used. Still have the whiskers on the sides.
Next, some 6 lug axle shafts from a 1992ish 8 1/4 axle that I converted to 5 lug.
Also, the original 7 1/4 rear axle, less the gears if I don't find some elsewhere. The 3.55 gears will be put into an 80 diplomat that I keep in Arizona, it has a slant 6 and could use some truck gears to make it a better city driver. Axle can go drum to drum if someone has some loose gears to trade...
Rear step bumper, black....
Cat and exhaust pipe for a 4 cylinder, cut about a foot behind cat....
sand blasted v6 intake manifolds, one for carb, one for TBI.
A500 OD trans, rebuildable...
Parts needed, some better gears from a 7 1/4 axle to replace the 2.7 ratio gears that are in my 80 diplomat coupe with /6....
3.2 preferred, maybe 2.9 will do...
Don't know if you posted this in the classifies on this site. Or post it up on www.craigslist.org or www.ebay.com
