46rh tranny
Old Jul 10, 2010 | 04:16 PM
Danton88's Avatar
Danton88
Default 46rh tranny
How much power can the 46rh handle stock and does anyone build them stronger? the most im wanting to put to the ground is probably gonna be around 300-350 hp range but that could change later down the road
Thanks.
Old Jul 10, 2010 | 06:30 PM
CentralTexas's Avatar
CentralTexas
The 46rh is actually a pretty good transmission and any transmission rebuilder should be able to build it stronger. It’s basically a 727 or TF8 transmission that has an overdrive section where the extension housing used to be to give you a 4th gear. The old 727 was one of the best automatics made. If they’re serviced regularly and not badly abused they’ll last a long time. The 46rh was used behind the gas V8's. The 47rh was used behind the Cummings turbo diesel and was a slightly beefed up version of the 46rh. I suspect a 46rh in good shape would hold up pretty well behind 300-350 hp, unless you’re really beating on it. If it needs to be rebuilt it can be upgraded with 47rh internal parts very easily and inexpensively.
Old Jul 10, 2010 | 08:22 PM
95_318SLT's Avatar
95_318SLT
Put in performance clutches and a shift kit, keep the fluid cool, and that transmission will last a long, long time behind a measly 350 hp. The TF 727 is a very popular drag racing transmission, so people have put more than double that power to one.
Old Jul 11, 2010 | 02:04 AM
Crazy4x4RT's Avatar
Crazy4x4RT
www.Phoenixtrans.com does HD versions. Great reviews. Here is a great article on how to build a HD 46re(IIRC) which is almost the same as the 46rh.
https://dodgeforum.com/forum/1st-gen...ml#post1735842
Other good transmission builders are
http://www.apsprecision.com/OEMTransmission.html
http://www.dreviltransmissions.com/home.html
Old Jul 12, 2010 | 08:02 AM
Danton88's Avatar
Danton88
Thanks for all the replys and the info it all helped out alot
