NP231 problems
Old Jul 11, 2010 | 07:57 PM
bluefrog's Avatar
bluefrog
Default NP231 problems
I have just had my 2nd blown tcase in a year and a half. How do I prevent the chain from slipping off and eating the housing? Is this an adjustment issue or a chain problem? Any ideas? Now too poor to just have it repaired.
Old Jul 11, 2010 | 08:33 PM
95_318SLT's Avatar
95_318SLT
Can you give some details on when you use 4x4 (NEVER use it on dry pavement) and how you shift through the t case selections, etc. The chains in these t cases are tough, so if you are using it properly, it should not break easily.
Old Jul 12, 2010 | 06:18 PM
bluefrog's Avatar
bluefrog
I do not use the 4 wheel very often, espc. since it is completely stock. 4h is usually all i ever need and i always shift into it off pavement. The chain did not break, but slipped off of the gear that drives the front shaft and ate a nice hole in the bottom of the tcase. I have put some photos of the damage in my gallery.
Old Jul 12, 2010 | 06:24 PM
bluefrog's Avatar
bluefrog
Here is a pic of the chain
Old Jul 12, 2010 | 06:28 PM
bluefrog's Avatar
bluefrog
Here you can see where the loose chain ground the sides of the housing
