i dont have headlights
Old Jul 13, 2010 | 11:49 AM
92ledakota's Avatar
92ledakota
Default i dont have headlights
hi,
i have a 92 dodge dakota le ex. cab with a 318. the problom i am haveing with it is that the head lights wont turn on. now when i go to turn them on i get dash lights, ambers, tail lights, plate lights but no head lights. also when i go to turn on the brights they will flash and then trun off. i dont know if it is the light switch or somthing with the wireing, or even the multi function switch. its been a good truck this is the first real problom iv had with it. please help.
thanks
Old Jul 13, 2010 | 12:26 PM
Crazy4x4RT's Avatar
Crazy4x4RT
First check the fuse. Then check the wiring. Check for power at the headlights. The service manual has a way to test the switch. You can download it in the FAQ2 in this section.
Old Jul 14, 2010 | 12:20 AM
92ledakota's Avatar
92ledakota
ok thanks, i check it out in the moring.
Old Jul 14, 2010 | 02:49 PM
melodytoinvent's Avatar
melodytoinvent
Did you pull the switch all the way out and not just far enough to turn the running lights on? lol j/k man. Hope you fix your problem.
Old Jul 14, 2010 | 10:41 PM
92ledakota's Avatar
92ledakota
ha, yea i did doublw check that. but it was what everyones problom is the dum headlamp switch. got a new one at advance poped it in all fixed. it was recomended to put at relay in tho.
