HELP please! =]
Old Jul 13, 2010 | 09:36 PM
dodgedak0tA's Avatar
dodgedak0tA
Default HELP please! =]
okay, i just bought a new radio, and i really need help hooking it up in my '91 dodge dakota all the wires are all flip flopped and wierd colors and i need some help ASAP
RADIO WIRES
___________
Black(ground)
Green/black strip
Gray/black strip
Red
Purple/black strip
Gray
Purple
Dark green
White/black strip
White
Yellow
TRUCK WIRES
___________
Yellow
Orange
Pink
Blue/Red strip
Brown/Red strip
Black/Yellow Strip
Red/White strip
Blue/White strip
Dark Green
Purple/white strip
Brown/yellow strip
blue/brown
Please help me out with this i need to know which wires to connect to which to make my new radio work
Old Jul 13, 2010 | 09:47 PM
95_318SLT's Avatar
95_318SLT
Welcome to DodgeForum!
What kind of radio? Is it an aftermarket cd player, or a different factory radio?
If its aftermarket, it should be labled what each wire is for. Just buy one of these...
http://www.crutchfield.com/p_1207018...s.html?tp=2977
You can probably find it even cheaper at Walmart, but really, $10 and its color coded to the wires coming out of the aftermarket unit and then plugs right in.
If its another factory unit, you need to review the wire diagrams...
Wiring Diagrams:
1990 Dodge Dakota(PDF, 5.6MB) http://rapidshare.com/files/20549398...ota_wiring.pdf
1994 wiring diagrams (non-Chrysler made), PDF, 1.4MB http://rapidshare.com/files/15954448...omplete_1_.pdf
1995 wiring diagrams, PDF, 6.8MB http://rapidshare.com/files/205477308/1995_AN_WIRE.pdf
1996 wiring diagrams, PDF, 6MB http://rapidshare.com/files/205480159/1996_AN_WIRE.pdf
http://www.the12volt.com/ (Radio wires)
http://www.bulldogsecurity.com/ (Car alarm/ remote starter wires)
Not what your looking for? Keep in mind that if your truck is close to that year, it's wiring is probably similar. You can also try this Auto Zone web-page.
Quoted from FAQ.
Old Jul 13, 2010 | 10:02 PM
dodgedak0tA
it is a jvc KD-S25 i bought it from wal-mart :P
Old Jul 13, 2010 | 10:26 PM
Deerkiller9991's Avatar
Deerkiller9991
Thumbs up
i have a '91 too. go buy the harness thing from walmart, it plugs into the stock plugs then has wires to connect to the cd player, easiest thing ever, wish i would have known they made those for my other vehicles
Old Jul 13, 2010 | 10:30 PM
dodgedak0tA
oh crap really? i already cut the wires should i just reconnect the stock ones then
Old Jul 13, 2010 | 11:33 PM
95_318SLT's Avatar
95_318SLT
That would probably be easiest. One of those links I gave you listed the radio wires and what they do...
http://www.the12volt.com/installbay/...etail/694.html
... but the colors don't match what you listed!
So solder the old harness back on, buy the adapter like I linked above (like previously said, you can pick them up from walmart)...
... and solder it to your radio connector and then it plugs right into the factory harness.
