93 Dak Fuel Pump Problems
Old Jul 21, 2010 | 10:29 PM
LESchwartz's Avatar
LESchwartz
Unhappy 93 Dak Fuel Pump Problems
I have a 93 Dakota w/ a 3.9 & 5spd. Over the last few weeks, it's been stalling out. If I shoot starter fluid down the throttle body, it will start right up. The fuel pressure was low, so I replaced the fuel pump. The pressure is good, but it still stalled. I went ahead and re-soldered the splice under relay box (as noted in the FAQ), even though there was no corrosion.
Then I noticed that I could get the truck stated if I wiggled the wiring harness where the wires split off to the fuel pump. I figured I would check the connections, so I pulled the connector, disassembled it, cleaned the connections, greased and reassembled. The connections looked good, no corrosion, etc. Unfortunately, now the truck wont run at all (wiggle or not).
I'm pretty sure the connector is the problem, but every salvage yard in town drops the tanks and cuts the harness with a wire cutter
Any idea where I can find a replacement connection?
Any suggestions for other things I've overlooked?
Thanks in advance,
Larry
Old Jul 22, 2010 | 02:56 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Did you replace the inline fuel filter?
You can replace the pins inside the connector. I would say if it is the connector that is bad and not the wire just cut off the connector and get a universal one from auto zone or radio shack. Get one with a weather insulator.
Or just splice the wires together.
Old Jul 22, 2010 | 10:22 AM
LESchwartz's Avatar
LESchwartz
I've replaced the in-line filter when I did the fuel pump.
As for getting a connector at Autozone, et al: I wasn't aware they even sold such a thing.
Larry
Old Jul 22, 2010 | 05:27 PM
Crazy4x4RT's Avatar
Crazy4x4RT
They sell universal ones.
Old Jul 31, 2010 | 11:03 PM
LESchwartz's Avatar
LESchwartz
I looked around Autozone for about a half hour, and didn't see any five pin connectors . . . I guess I'm not understanding what you mean.
Larry
Old Aug 1, 2010 | 09:27 AM
tmacdakota's Avatar
tmacdakota
That's an electrical part, if it's not on the shelf as the counterguy.
Old Aug 6, 2010 | 06:44 PM
kevin2502000's Avatar
kevin2502000
Here's what I did as I had the exact same problem on my 93. After many many headaches I found that dodges have ****ty wiring harnesses. After attempting to solder a broke wire I found the main wire to the pump had corrosion throught the entire wire. I ran a new wire from the fuseblock straight to the pump. I even by-passed the 5 pin connecter and drilled a hole in the top of the pump connecting it directly to the motor inside. If you can use your plug I would do it for ease. I may even have an old one lying around here if u need it.
Old Aug 9, 2010 | 03:17 PM
LESchwartz's Avatar
LESchwartz
Default Update
UPDATE: I dropped the tank enough to work on it (yet again), and used a pliers to "tighten" the connection. Afterwards, it started right up. Once I got it started, I used hot glue to try and keep the connector tight. The test drive went OK, but I'll have to drive it for a week or so before declaring victory.
BTW: This must be a known TSB issue. See RockAuto's information on the Airtex pump: http://www.rockauto.com/catalog/moreinfo.php?pk=59831. Notice the first bullet point
Larry
