Brake lights
Old Aug 2, 2010 | 10:28 PM
96dodgedakotey's Avatar
96dodgedakotey
Default Brake lights
My brake lights are not working!! Do not have owners manual so I have no clue if there is a fuse that might have blown and I will not go ONE BY ONE!! They light up with the headlights and turn signals work. Is it a fuse or a relay if anybody can give me a link to the fuse box layout or can just tell me the fuse or realy #, or if the problem is even a fuse thanks...
Old Aug 2, 2010 | 11:02 PM
Dodge4lyfe's Avatar
Dodge4lyfe
I suspect brake light switch on pedal is the culprit, if the fuses are good...
Old Aug 3, 2010 | 09:14 AM
MRS_ROCKIN_ROBIN's Avatar
MRS_ROCKIN_ROBIN
I too, would suspect the brake pedal switch after checking fuses.
Hope this helps!!!
Merrie
