Blew up my T-case!
Old Aug 3, 2010 | 03:41 PM
Z Guy's Avatar
Z Guy
Default Blew up my T-case!
completly destroyed...
as a transfer case swap out is obviously in my future i was woundering if any of you had some good tips and tricks to swapping it out. anything that may make it easier
I have a 94 ex-cab w/ the 318 manual..
Old Aug 4, 2010 | 01:59 AM
Nathyne's Avatar
Nathyne
stubby 14mm ratcheting wrench made my top two bolts a breeze apart from that it was very straight forward for me.
Old Aug 4, 2010 | 07:40 AM
Dodge4lyfe's Avatar
Dodge4lyfe
yeah, it's really not as bad as you might think...I did mine myself, took 2 hours...
Old Aug 4, 2010 | 08:50 AM
tmacdakota's Avatar
tmacdakota
If you blew it up literally, you may have had problems before or stressed something inside by staying on it. TC's are not standard tranny's, they won't take as much abuse and keep on ticking. Maybe you can find a good, used low-mileage replacement.
Old Aug 6, 2010 | 12:55 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Yes I agree. A bendable one helps too.
Also replace U-Joints and straps/retainer bolts.
Old Aug 10, 2010 | 03:05 PM
Z Guy's Avatar
Z Guy
thanks for the info guys..
ya the t-case was bad and clicking with a small leak when i got the truck. Drove it around for about 10 months refilling it often until it pretty much grenaded on me... Barely got it home
Old Aug 18, 2010 | 07:08 PM
Z Guy's Avatar
Z Guy
why is nothing ever easy for me!!!??? first 5 nuts came off in about 7 minutes. The top passanger side nut is in the hardest to reach spot in the world to put torque on!
you can get a wrench on it, but there's no space to turn it. could get a socket on it, but ratchet won't fit in the space. tried one of those super bendy extentions, but couldn't bend tight enough. finally used a wobbly end to a 90 degree socket that gave me just enough torque to crack it loose...
then the guy who had the truck before me felt that it was a good idea to not replace a broken bolt for the driveshaft clamp, but intead weld the clamp on... so ya that was fun
Old Aug 19, 2010 | 02:42 PM
dodgerules86's Avatar
dodgerules86
FYI, if you remove the bezel and shift boot cover from the 4x4 shifter (in the cab), it gives you easier access to the top transfer case bolts.
Old Aug 19, 2010 | 03:18 PM
Z Guy's Avatar
Z Guy
ya thats how i got to the top driverside nut... didn't work for the passanger side though
